Help Idle jumps
Discussion in 'General Tech and Maintenance' started by azskateman, Mar 16, 2004.
  1. azskateman
    azskateman Junior Member
    Anyone had any experience with the idle jumping from about 800 to 1300 and then back again? I do have a check engne light witch is because of the Knock sensor but it only comes on when the car has heated up.
    Dustin
  2. Tim@Canspeed.com
    Tim@Canspeed.com Member
    The problem is quite common with Honda engine swaps. I've found alot of different reasons for this problem to occur so a simple answer I cannot give. I can say that the first thing you should check is your coolant level. Make sure it is topped up and no air locks are present. An air lock in the system can prevent coolant from reaching the Idle Air Control motor and will cause the IAC not to function properly. Search the problem on this web site. I thought I seen an archive or something on this very problem.
  3. 95sir
    95sir Senior Member
    can a clogged filter on the iac do that?
  4. slammedb18acivic
    slammedb18acivic Senior Member
    pa
    mine was the tps, took a throttle body of a 97 ls... wrks fine now
  5. civic_types
    civic_types Senior Member
    Mine was the throttle body gasket + throttle body adjustment
  6. highperboi
    highperboi Senior Member
    Alameda, California
    how does tps make idle go up?
  7. randerson165
    randerson165 Senior Member
    Eugene, Oregon
    That whole engine is sensors and the TPS is a sensor, if it is bad and not reading correctly or sending info incorrectly, your engine will not respond accordingly. A bad TPS is pretty common is swaps.
  8. Bl6CRX
    Bl6CRX Senior Member
    UCLA
    yeah mine was like that too after my swap, however, my problem was that the spring was stuck, remove it an if necessary replace it...
  9. highperboi
    Alameda, California
    how do you take the TPS off?
  10. cws13
    cws13 Senior Member
    Athens,GA
    I'd start with the cooling sys having air and checking the IAC valve first. If the TPS is ok, you take it off it will be out of whack after moving it.
