Civic_mike74
I hope you lot can help because ive been getting so much different information.
I have a 96' civic coupe SR which i belive has a D16Y8 and is OBDII, Im not sure what the EJ or EM number is (if anyone could tell me??)
I am most of the way through my engine conversion. I am putting a B16A2 engine and a P30 ECU out of a '94 Civic Hatchback VTi which im told is OBDI. Everything fits apart from the wiring...
I was told that all i would need is a conversion harness that you can get from Skunk2 but others are saying that i will need the full wiring loom from the '94 Civic hatchback VTi. If i get one of those do you think it will work?
Also there are 3 grey wires coming out of the side of the engine which i have no idea where they go??
Any help or information would be greatly appriciated as im carless untill this is sorted!
Thanks
Mike
Thanks
Mike
