94_gs-r
can you say 260 whp N/A??
i am currently doing a build on my gsr block. basically all i need to know is that if i take my gsr block and put an ls crankshaft on it i have a lager stroke do i need shorter rods or can i use my gsr rods. the only thing i am worried about is that since the gsr crank is smaller and ls is larger and the gsr crank makes the pistons flush with the deck if i use an ls crank and my gsr rods in my gsr block and put itr pistons in it will they come out the top of the block, do i need custom shorter rods? i dont want my piston to hit the head, or will this be fine and i can put it together no worries..
