in theroy yes , but as you said the difference in injectors sizes , would cause me concern , if it works and you drive , drive i very slow , i really only suggested you try it to see if your ecu is bad , the only changes between wiring arethe iavc , add vtec wirring . and add knock sensor , and and ckf sensor correct
