I hope I am posting in the correct place. My apologies if I made a mistake.
I am doing some research before I go out and buy a civic. Can you please give me your experience? I would appreciate it.
I am looking to purchase a honda civic with a high mileage. I have a desire to learn how to do an engine swap. I plan to remove the engine and replace it with a rebuilt engine of the same stock to avoid problems. I want the engine swap to be as easy as possible, being my first engine swap. Once I learn how to do it, then I can later experiment. One step at a time.
What is your opinion on the year civic I should look for with the following in mind;
1. It needs to pass smog once I do an engine swap. Can I use JDM engines being in Southern California? Is it a good idea to buy jdm?
2. Easy engine swap with the same type engine.
2. Is a used engine easy to find on the net or ebay?
4. I need airbags.
5. What engine number? This is so I can find it on ebay or net.
6. Is there a business you have had experience in buying an engine.
7. Am I out of my mind?
Thanks for your time. Your opinion is valuable to me.
