I am stuck between these three tires...
azenies
Potenza S03
Kumho's MX
Well, here is the reason why I just didn't go straight to the azenies. Major factor is the rain capiblities. This fall I am going up to tech, were they get a decent amount of rain in the fall. I am going to take my car up there for "spirted" driving. With both the s03 and the MX's, they are great in the rain. Also, since I will be doing alot of highway driving, were is slightly an issue (but not much)
The run down on each tire.
Azenies -
Stick like glue,
get greasy with alot of hard use,
Stiff sidewall,
suck at water,
fairly heavy, and
wear pretty fast.
S03's. Had them before, loved them for the most part. Very sticky,
EXTREMLY stiff sidewall,
great at water until treadlife is below 40% or so. Treadlife is ok, only slightly better then the azenies. They weigh a little less then the azenies.
Also, great grip great even before they heat up.
MX Have heard alot of mix reviews
GREAT in the rain
weigh the least out of these three tires
Better treadlife
sh*tty sidewall (which I have heard upping the PSI can cominsate)
Little less grip then the azenies.
I will be using these as my Daily driver tires, however, as always, I will be hitting up autocross's again, and also want to hit Gingerman a few more times this summer.
Prices are all about the same within about $20. For the azenies, I can get them mounted for 310 a set. With the MX and the Potenza's, I will have to pay for shipping then mounting, so probally the diffrence will be alot more. Back when I had the potenza's, even though they were around 70-75 a tire, after shipping and mounting, the total was closer to $100
azenies
Potenza S03
Kumho's MX
Azenies -
Stick like glue,
Stiff sidewall,
suck at water,
fairly heavy, and
wear pretty fast.
GREAT in the rain
Better treadlife
