Help me pick a turbo
Discussion in 'Forced Induction' started by label3002, Jun 21, 2008.
  1. label3002
    label3002 New Member
    Ok first of all i have an ls/vtec.I have all the stuff neccesery to put on a turbo. What i want to know is which turbo would be good, I plan on pushing 300- 350 whp. Also want to be at full boost by 3500 to 4000.So i was looking at garrett t3/t04e and was wondering if that would be a good turbo also what trim would be the best choice. any advice please/
  2. t3t4delsol
    t3t4delsol New Member
    York, Pa
    whats your budget?
  3. label3002
    My budget is around $500 and $800 also im only planning to run around 7-8 psi and tuning.
  4. Matts96HB
    Matts96HB . Moderator VIP
  5. label3002
    So at what rpm would the garrett t3/60-1 be full boost by.Also what a/r housing would be good cause i have a 5 bolt down pipe.
  6. 92colesi
    92colesi New Member
    434 VA
    i helped my roommate put a 50trim t3 on his integra, full boost before 4 grand, and he got his for like 300.
  7. efhondakid
    Akron-Canton, Ohio
    Sorry I just have to do this..:D
    This one.
  8. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    Lmfao.
    Garret 60-1 is my choice. But its not going to spool until after 5k rpm.
  9. efhondakid
    Akron-Canton, Ohio
    T25 would be a good choice for a quick spool, but correct me if Im wrong, will surge out before making those numbers right?
  10. awptickes
    MD
    efhondakid: Coirrect. That turbo is wayyyyy too small for a 1.8l engine.
    You want a t3 or a t4.
    Get a chinese t3, run an oil flow restrictor, and you'll have a decent power curve for a couple years. (contray to popular belief, the chinese eBay turbos aren't half bad. Given, they're not as good as a garrett or a KKK, but they work pretty well. Just remember the oil restrictor.)
    Read the http://hondaswap.com/turbo-information/building-homemade-turbo-kit-81384/ thread. Then read Homemadeturbo.com Then read some more. Don't buy anything until you've got everything you need laid out on paper.
  11. Turbo&Auto
    Turbo&Auto Nick Go FAST!!
    East Burg, PA!
    My vote is a 50trim with .63A/R. There was a local kid running one in his GS-R, he made 385whp with a block guard and really not much else to the internals. The car spooled pretty quickly and pulled to redline!
  12. label3002
    Well I guess, il be going with the garrett t3/t04e .63 a/r 50 trim any last opinions from anyone?:rolleyes:
  13. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    *raises hand* Have you upgraded your fuel system and are you running with stock internals?
  14. efhondakid
    Akron-Canton, Ohio
  15. Luis998
    Orlando, Florida
    I have them once in a while, though they are very rare. :D Just call me Captain Obvious. :ph34r:
    1 person likes this.
  16. label3002
    Yes I have forged pistons and the arp rod bolts and upgraded fuel system. I also have port & polished head and intake manifold.
  17. eg6sir
  18. newb
    newb phresh VIP
    Backwoods Northwest
    What about an O or P trim wheel in a T04B or T04E housing with a .50 or .60 hot side? Just tryin to give you some options.
