HELP me please!!!!!!!
Discussion in 'Accord' started by robbyho21, Nov 19, 2006.
  1. robbyho21
    robbyho21 Member
    binghamton ny
    alright i have a 94 accord with the f22b2 engine with a bad head, i need to know what other engines or heads will fit it. like i have a 92 accord with a f22a1 or 2 will that fit and bolt up too the tranny(auto). what about H22 or H23 would they bolt up to my tranny? or would an h23 or 22 head fit my block. if anyone can help me out with this i would much appreciate it, or anyone with parts that will work. ive put an engine in a 95 civic a few months ago, was pretty simple i think especially since it was my first engine swap and it went smooth. HELP ME PLEASE!!!!!!!!:ph34r:
  2. powerdriverh22
    powerdriverh22 Senior Member
    spfld, mo
    the heads from the 90-07 accords all work. if you want a vtec head the f23b1 is the one you are after it came on the 94-97 accord ex's. you would have to get a new ecu and wire the vtec. yes the h22 or h23 heads will work but not direct bolt on. there would have to be some modification done to the block and head gasket. all of the f and h series motors will bolt up to your tranny
  3. robbyho21
    robbyho21 Member
    binghamton ny
    thank you for the info!!
  4. BrutalB83
    Rochester Hills, MI
    I think you meant the F22B1. They didn't have F23s until the 98-02 body style. But yeah, slap that F22B1 head on there (and the appropriate ecu of course) and you've repaired your car, plus gained VTEC and a few extra ponies.
  5. powerdriverh22
    spfld, mo
    ya i did but the f23 head will work just the same
