Help, Need to install the power harness for JDM fog lights
Discussion in 'Civic and del Sol - EG and EK' started by kenoverby, Jan 4, 2011.
  1. kenoverby
    kenoverby Junior Member
    Can someone post the JDM instructions for the JDM fog light harness. Thanks.
    I have been searching all over the net. The USDM harness instructions show it pluging into the back but mine plug into the accessory terminals on the front of the fuse block. I need to know witch ones to plug into. I have done it befor and it worked. Basicly I don't have the foglight harness installed but the switch and power harness is installed and grounded but I can't here the relay tick. So can someone confirm the plug terminals. I have read the fuse block and it reads plugs from left to right are numberd 5-4-1-2-3. The wires read a 2 and a 4 "I think, but I don't remeber the wires correctly". So where do the wires go. hehe. Also my fog light relay may be bad and I will test it tommarow. The thing is that maybe my bulbs in the switch are bad since they don't turn on either =(. Ohh well...
    I need this ASAP because there is a big driving hazard in my route on the freeway with fog at night. thanks.
