M MrS900N Junior Member Jan 5, 2006 #1 Hi i have a ek which i have put a B18 lump in. im using a obd2b engine harness and a adapter to a chipped obd1 ecu. My question is what to do with the o2 sensor from the ek with obd2b B16a2 engine.... it is currently a 3 wire will this work?? Please Help Dan
S sheekdude Member Jan 7, 2006 #2 I'm sorry but i don't understand the question!?!?!? What year ek? What year motor? All you i understand is that you have an B18 motor(obd1? obd2a? obd2b?) and a obd2b harness!! I know your ek will have 2 o2 sensors one before and one after the cat. The ones on the car should be four wires.
