Help Needed b16a obdo
Honeypooh
:confused:I have a B16a DOHC running on a obdo cumputer, the exhust mani, has two o2 sensors, how do i wire them into the ecu, if i don't will i loose any power, if they are abandoned?​
One option you have is to wire the two sensors in parellel. This what i had alot of guys tell me to do when i had the same problem but i just hooked up one and forgot about the other one. have fun!
Hook up both o2 sensors to the ecu, I am not to sure off the top of my head what pins they are but the obd0 b16 runs 2 o2 sensors. I wouldnt wire them together i would run them the proper way. Just my opinion. I am sure someone knows where the sensors need to be run too.
