Help!!! New guy that needs help with 98 Civic
Bktuner09
Looking for advice as I own a Civic coupe with a single Cam motor that I would like to build...I would like to add a T4 turbo kit and Im aware that I need injectors,ECU tuning and perhaps a fuel regulator. The car is an automatic but I plan to install a stall converter which will increase Rpms between 400-800 rpms. the vehicle has exhaust and cold air intake as well. Please respond if you can give me advice. Thanks
wow that'a what everyone says...thanx I just needed an outside opinion. I had someone convince me that if I added a stall converter that it might beef it up a bit. I wanted to use it as a method to maintain maximum boost as turbo feeds from exhaust and with shifting the boost wouldnt remain constant....any ideas?
