d17type-R
Doc Brown says
actualy i do have expiereence , not to sound coky but i am an auto electrician and almost everyday we bridge past a suspect part in a circuit to iliminate it and diagnose the problem. all the dimmer switch is is a varible resistor, bridging across it would be like turning it on high. if you are unshore try using a test light to bridge across it, this has a globe in series to put a resistence across the circuit, better yet use an led or multimetres and check power at both ends and continuity across the dimmer, or best of all take it to someone who knows, like an auto electrician
ACTUALLY, if you remember from tech school(providing you went to one of those) that all bridging across a circuit does is shorten the circuit path and in effect you compromise it by creating a "flat short".... this is bad news because it creates unwanted heat in the circuit wiring which can in turn lead to an electrical fire. Not only that but since I happen to own pretty much the same car...(2000Si vs. 2004 LX)... you would think that having worked on vehicle electrical circuit systams for the last 8 years paired up with identical wiring added to vehicle specific experience would kind of make me more of the authority here.
I mean we're not exactly talking about a GM P.O.S. that it doesn't matter what you do to the wiring because the colors haven't changed in over 25 years or so. Hondas have a lot of delicate electronics that are designed to easily short so as to protect larger more costly components of the entire system.
Most people can't even figure out how to get the RADIO out of a newer Honda without making a few phone calls first, let alone open up the multipin wiring harness that the HVAC connects to.
It's ALWAYS a beter idea to use a multimeter. And as long as you know what wire to test and what you're looking for whether it's "grounding" "shorting" or has a "hot spot" then you're ok. But other than that, I'll agree with you and restate what I already said........
Originally Posted by d17type-R
Rule of Thumb: "Do it right, or Pay someone else to do it"^_^
