Help No Injector Pulse
Discussion in 'HYBRID -> ED-EF / DA' started by terror_si, Feb 4, 2007.
  1. terror_si
    terror_si Junior Member
    I Have An 88 Hatch And I Have No Injector Grouind Pulse But I Have Power To Them What Should I Check
  2. 801CRX
    801CRX Got Rice?
    UTAH
    All your wire connections!
  3. terror_si
    i have pinned back to ecu its all good `where is the thermostat ground go to in the ecu what pin i was told that that could be the problem
  4. 801CRX
    801CRX Got Rice?
    UTAH
    Is the motor swaped or stock?
  5. terror_si
    swaped B16 it ran for the first 2 days fine and now wont start has no pulse
  6. 801CRX
    801CRX Got Rice?
    UTAH
    Hmmmmm...............ummmmmm
    Got me stumped
    What ECU are you running?
  7. terror_si
    p 28 not chiped for duel camright now
    its the only one we had laying around
    its an auto by the way if that makes a differance
  8. 801CRX
    801CRX Got Rice?
    UTAH
    Did you use a resistor box?
  9. terror_si
    no i put an 11.5 ohm injector in it
  10. terror_si
    help
    any on else have advice how do i no if the ground is good
  11. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    Which one, the car, or the ECU?
  12. terror_si
    i have no injector pulse what makes them pulse and is the ground to the computor good i cant find out
