HELP ?? obd2 97 accord put in h22 obd1
ra7racing
recently put a obd1 h22a into a 97 accord obd2 need help on wiring dizzy up or should i get a 97 up prelude obd2 dizzy ? can i use an 97 up prelude ecu or convert to a p13 obd1 ??any other info will help to thanks
nope, I'm pretty sure you'll have to rewire your harness to the OBD1 motor and dizzy. An OBD2 motor would have the sensors in different places on the motor, and not in the distributor. OBD1 has the sensors in the dizzy, which would make swapping it out for OBD2 near impossible.
You can use a conversion harness at the ECU, to run an OBD1 P13.
Buy a Helms manual.
