HELP:obd2a to obd1
Discussion in 'HYBRID -> EG-EK / DC' started by so_so_swift, Mar 9, 2007.
  1. so_so_swift
    so_so_swift Junior Member
    i got a obd1 b18b1 motor and swaped it into my 96 ek DX hatch and having a hard time figuring out how to convert the harness to obd1... how many plugs would i have to change? i have the jumper harness already... juss the wiring harness from the firewall to the motor... HOW MANY PLUGS DO I HAVE TO CHANGE AND HOW MANY ARE NOT PLUG TO THE MOTOR...??? LET ME KNOW HAVING A HARD TIME AND BOUT TO KILL MYSELF...
  2. boostin4fun
    boostin4fun Boosted ls/vtec ohh yeah!
    Omaha
    This advice is assuming that everything on your engine is obd1. You would need to change the distributor plugs, injector plugs, and i think the alternator plug. But to make things a little easier try and find some ls obd2 injectors so you wont have to hack the plugs off. Also you could get a ls obd2 distributor and alternator to save even more chopping if you wanted. That would make your harness plug and play.
  3. JDM_EK9R
    JDM_EK9R all motor
    central, NJ
    whoa...i thought if you have the jumper harness you dont need to change anything. could be wrong but im almost positive. i had a 99 b16a2 in my ek hatch and i ran an obd2a-obd1 jumper with a p72 and i had no check engine ... nothin
  4. b18c1vic
    b18c1vic Junior Member
    No what they are talking about is the engine side of the harness and changing over all the engine wiring, due to the fact of the motor being obd1.
  5. so_so_swift
    on the distributor i want to change to a obd1 plug and how do know which color goes where...
  6. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    i gott a p28 ecu for my obd1 jdm d15b...anyone know what o2 sensor i have to use? is it the 4 wire?
  7. boostin4fun
    Omaha
    Yes, you use a 4 wire o2.
  8. HATCHET_HONDA
    hobart, indiana
    so the wires form the obd conversion harness are used on the new sensor righ? just leave the one wire plug unhooked from the engine harness?
  9. boostin4fun
    Omaha
    Yes
  10. slickzsmilez
    slickzsmilez New Member
    hey hachet honda I have a d15b and doing a swap in my 97 civic with it what do I do to get the distributer plug to work with the engine wiring harness its a obd2 car but the engine and distributer are obd1.
  11. jdtim
    jdtim New Member
    Minneapolis, MN
    damn.. i always that that if you get the conversion harness, everything is plug & play...now im not as excited for the swap as before...
