Help on a 96-00 D15B swap in 93DelS D15B7
godspell
I'm thinking of swapping a newer D15B into my 93 Del Sol D15B7...
Any ideas on what will need changing.. I'm assuming the ECU and wiring harness...
Tony
NJ
is it a jdm d15b with vtec?? if so you will need harness and a jdm p08 ecu, you can use a usdm p28 ecu but its not the same as the p08. the motor seems to run a little better with the p08.
Thanks for the help...
The engine is a non-vtec, which is just like what I have now... does that mean I can reuse my harness and ECU...
Thanks again,
Tony
Are you sure it's from a 96-00 Civic? To my knowledge all 96-00 Civics had D16s, even the DX versions, unless the motor you have is some obscure JDM or EDM thing I've never heard of.
