Help on b16 swap Wiring pics 56k warning
Discussion in 'HYBRID -> ED-EF / DA' started by Citizen_Insane, Mar 20, 2004.
  1. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    1. I assume these are connected correctly. Just making sure they're in the right order:
    2. Moving to the back of the block...Which of these wires goes where...or does it matter??? (Yellow or black on top?!?)
    3. Can someone please tell me what this is and if I need to wire it?
    4. I found this ground and I don't know where it goes:
    5. I just want to be sure I have identified these correctly:
    6. WTF is this and where (if at all) does it connect?
    Thanks for the help.
    -Kai
  2. UDT
    UDT Senior Member
    california
    This will be very helpfull to some one once answerd, nice pictures :thumbsup:
    Although you are missing the traditional :calban: picture....(with out the banned by call part ;) )
  3. Citizen_Insane
    Minneapolis
    GODDAMNIT!!! :lol: I thought u were going to help me out.
    oh well...TTT
    ...I'm going to go put in a clutch and when I come back someone better have at least tried to anser my questions :)
  4. UDT
    UDT Senior Member
    california
    :cockblocked: Yeah sorry to get your hopes up... :D one of the gods should be along here shortly.
  5. arpee79
    arpee79 Senior Member
    the black ground that goes on the thermostat housing,as for the 2 yellow and black i dont think it matters wich one goes on top or bottom.As for the top green plug thats your knock sensor for the last pic i dont know wtf that is .sorry
  6. Citizen_Insane
    Minneapolis
    The last pic is of some thing on my HF wiring harness.
  7. ef_hatch
    ef_hatch Member
    #1.
    looks good. just remember the injector resistor because it isn't pictured
    #2.
    i need to find out too but i don't think it matters
    #3.
    that would be your knock sensor. yes you need to wire it!
    #5.
    that is correct
    #6.
    no idea what that is! tell us what sensor it ran to before you removed the engine
  8. Citizen_Insane
    Minneapolis
    ^^^ What is an injector resistor??
  9. ef_hatch
    ef_hatch Member
    it looks like an aluminum heat sink cooler and 1 wire from all of your injectors will go to it
  10. Citizen_Insane
    Minneapolis
    Do I use the b16's injector resistor or the HF one??
  11. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    not sure whether the one from the B16a will work- but a injector resistor box from an 88-91 civic si should work just fine-
  12. crx
    crx Senior Member
    cali near sac
    hf resistor box will work, the last connector is for the hf's egr valve(you dont need it) just hook it up like it went you your hf and add knock sensor,oil pressure,and vtec sol wires, you also have to add a 2nd O2 or tap the 2nd o2 sensor wire to the primary and you should be set..
    -joseph
