Seany-izzle
Member
the plan is to keep my d16y8 internally stock. The goal is somewhere around 200hp. This is my daily driver. Will drive it on Rt 17 every so often. Wont be seeing track. Boost-around-town type of setup (mid range power). The turbo i will be using is a t25. planned amount of boost will be at around 7 or 8 psi.
What shoud i do in regards to fuel management? The choices are fmu/link (dont really want to), vafc hack, or the sds eic. I know that the fmu/link is the least desirable, and the sds is the most of the three. I dont have money for hondata or ems. Im thinking that the vafc will be sufficient, along with some 440cc injectors, for my needs. Am i correct in my thinking (that it will work well)?
Any thoughts, opinions, and/or experiences would be helpful. Also, if i left anything out that you want/need to know, just ask.
Thanks a lot.
Thanks a lot.
