P phengnhou Member Jun 3, 2004 #1 i want to do a ls swap into a 92-95 civic hatch. but i don;t know which motor will be easier or better for this is. should i use the obd1 or the obd2. ?
P phengnhou Member Jun 3, 2004 #2 and one more question. is there any other things that i need to do the swap other than. axles. wiring harness ecu and the motor and stuff..
xj0hnx I wanna be sedated VIP Jun 3, 2004 #3 At least make an effort, 1. Post in the right forum, there are swap specific forums for a reason. 2. The site has covered every issue you can encounter or have reguarding what to swap into what. Help is here.
