Help On This Swap.
nealo
I got myself a 1994 Civic hb si. Yeah. I know its the heaviest model and all that junk. I just wanted the car because i knew i would be rolling pretty much stock for a while. But yeah. Im ready for a swap. Which one do you guys reccomend for my set up here. b16a2/a3 or a b18b. TURBO will be in mind later on. way later on. Thanks guys.
B16A2 is OBD2, so unless you are really set on that--avoid it.
B16A3 is exremely hard to find, as it was made only in DOHC VTEC Del sols.
B18B will be your best bet for turbo--you should REALLY follow through on it, tho--B18B stock or N/A IMO is a waste of time
If you are set on a B16--get the JDM B16A SiR II.
Do you know if that b16 sir II will pass smog in cali tho. This is gonna be a daily driver and then off to the track whenever im extremely bored.
Cali smog guide from the FAQ
