Help! On Timing Belt Asap
Discussion in 'General Tech and Maintenance' started by skylineboy, Jan 15, 2003.
  1. skylineboy
    skylineboy Junior Member
    I think my timing is wierd. when i turn my cam sprocket to the position up, which says it on my cam sprocket, the rotor in my distributor cap points to spark plug #4. What should i do now?
  2. djextremity
    djextremity Senior Member
    in your rearview mirror..wait..
    Take off the distributor, spin the little tooth thing that spins with the cam 180 degrees, put it back in and you should be fine. Remember--Honda I4 engines fire 1-3-4-2, so you're 180 degrees out of phase. Just spin it!
  3. cws13
    cws13 Senior Member
    Athens,GA
    That distributor should only go on one way. And if the timing was that far off the car wouldn't be running. Perhaps some misrouted plug wires...?
  4. pissedoffsol
    was it tuned/timed with a timing light?
