Help Please - Crx Obd-0 To D15B Vtec Obd2A
Discussion in 'Civic and CRX - EW' started by Komet 163, Oct 12, 2015.
  1. Komet 163
    Komet 163 New Member
    Chile, South America
    Hello Honda owners.....my name is David, I'm from Chile, south america....
    I have a question, and I think here is the place where you can help me....I have a 85 CRX Si, which came with a EW3 MPFI engine OBD-0- and I'm changing the engine for D15B VTEC OBD2a. I have all the engine harness OBD2a with the ecu. and I have the whole interior harness OBD-0
    I want to match the engine harness OBD2a with interior harness OBD-0 .... and so have completely operating the cluster, and the other things to the engine to run properly
    someone who knows how to do it..to know what wires i have to look...thanks
  2. Briansol
    This is going to be a very difficult conversion. You must run the obd2a ecu in order to hit the 3-stage vtec. you're probably one of the first to really attempt this that I know of.
    Good luck! and if you can document what you do, you'll be an internet hero!
  3. Komet 163
    I drew on paint to see if you understand what I need to do
    I need to match both harness, but I need to know that wires will use and which are not
  4. Komet 163
  5. Komet 163
    I would like someone expert told me, if I'm right or wrong
  6. Komet 163
    somebody.... this is honda swap!!!
  7. Komet 163
    i think definitely it's the most difficult swap question of the forum in many years....
