mikeyrocks6
ok well i just got head out of machine shop they did everything valves seals shaved port polish hot tanked evrythign.....then i got it back i left everything on it and i put it on my car... i gotall new gaskets new oil everything...i wanted to no why my car white/gray smokes maby baby blue but im thinking white...it i down shift then hit it it does it bad even at idel tho...could the head gasket be on upside down could it be that i lubercated like the pistons and block when it was sitting cause i didnt want to rust and i really didnt wipe it away....i meen please help i just put 1000 into my engine and put it together and now it smokes bad every rpm...help please thanks mike email is frenchgolfclub@yahoo.com
compression cold 185psi all the way across no leak block test came out good
