Help Please
Discussion in 'HYBRID -> EG-EK / DC' started by MR. EG, Mar 5, 2003.
  1. MR. EG
    MR. EG Member
    i have just completed my b -20 swap into my 94 civic cx. it starts just fine but it idles very high.
    when i give it gas it dies. i dont know waht the problem is .i thought it was my TPS but i swapped my tps from my cx motor and the problem is still there.
    please help
  2. pissedoffsol
    any codes? what ecu? what throttle cable did you use?
  3. MR. EG
    MR. EG Member
    i used a 94 LS ecu. i have acheck engine light but dont know what codes yet. I t was late at night and i had to leave the shop i was in. as far as the throttle cable goes i used the delsol vtec cable that every body suggested but it has the wrong end piece and would not connect under the dash. therefore i had to use my stock cable and extend it. but that is not the problem. it dies even when i turn the throttle by hand.
