help pls 99ls swap in 92 integra
Discussion in 'General Tech and Maintenance' started by mario04, Dec 29, 2008.
  1. mario04
    mario04 New Member
    hosuton tx
    ok heres da tha thang me an sum friends are doin dis swap ona ververy low an tight budget meanin wit no money well we are swapin a 92 ls witch has no compression in 2 an 4 piston well i got a 99 ls but we were wonderin can we just plug an play pretyy much or do we have to mes wit obd1 or obd2 an my integra an obd 1 or 2 an is da 99 ls obd1 or 2 see wat im getin at im buyin a harness that might help but be sides that they said sumthi bout breakin da prongs on da origainl harness so can sum 1 ps help me email me here or at nawfsidemex04@yahoo.com thk im also sellin sum sidemeakers jdm emblems jdm visors an a rear type R lip an spoon mirrors manule all is brand new tryin to make sum money for dis swap
  2. George777
    George777 ^^ Likes Bewbies
    With your mom
    :emofo:
    And the 99 is OBD2. The 92 should be OBD1. A little research would have told you that.
  3. D16SiHatch
    D16SiHatch New Member
    yea seriously. that is quite painful to read.
    Like he said your car is obd1. the engine is out of an obd2 car therefore the dizzy is obd2. Use your stock harness. Put your old distributor on the new engine, run the stock ecu, and be done with it. you don't even have to switch injectors.
  4. mario04
    mario04 New Member
    hosuton tx
    lol thks well im still learnin i needa long way to go asyall can tell an this is my first swap my friend been busy so he told me research da info dint no were to look an he wasnt surebout da obd1 an 2 thks
