help pls.
Brokk
have a 98 civic si, and i had a 2000 civic sir powertrain installed with a 99 civic sir computer. but i keep getting the O2 sensor code. i have replaced it with a new O2 sensor but the CEL keeps coming on, does anyone have any suggestions or how to troubleshoots? and help is appreaciated
something about high voltage wire bank 1 sensor 2. hope that helps.
likely a short or break in the wiring somewhere
double check that first
make sure there are no breaks or its pluged in properly. also if you happen to have the wrong one. if it is a inch to long or a inch to short you will get the code. what is the exact number its throwing tho.,
