90 Hatch, ZC Engine, Integra ECU
Okay. I got 5 codes
6: Coolant temp. (sometime there some time not)
7: Throttle angle Sensor (same as above)
8: TDC Sensor (show up quite often)
13: Atmospheric Pressure Sensor (same as as 6 and 7)
20: Electric Load Sensor (always there)
Code 20 is always there, 8 shows up on it's own, but 6,7 and 13 come on all at once. They only come on when all 5 are there.
HELP!!!!! I'm on my second dist. and have two more coming from ebay. Hopefully one will work and fix 8!
Also, the engine ticks. Check and adjusted valves, still does it. Would the TDC being out cause that?
The timing was set without the jumper plug. I didn't know that it exsisted. What does it do. Does it make a big difference?
Any help[ would being greatly appriecated. I'm almost wondering why i didn't stick with the weak ass 1.5l
Okay. I got 5 codes
