help! removing connecting rod
Discussion in 'Engine Building' started by dc forever guy, Mar 4, 2009.
  1. dc forever guy
    dc forever guy New Member
    carrollton, Ga
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    the piston pins are pressed into the rod - you need to have them pressed out
  3. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    :werd:
    Preferably using the "Honda tool" although using an assortment of steel sockets would work if the mechanic is careful. Refer to the Helms manual*
  4. sdj02
    sdj02 New Member
    Sometimes you can take a small propane torch and heat the small end. This will cause the opening to open up a little more and allow the wrist pin to come out. Just keep the heat off the piston.
  5. K2e2vin
    Raleigh, NC
    I'm pretty sure it'll take more heat than that. I bought a set of pistons where some guy obviously tried to do that(rods had burn marks all over the PE ends).
  6. MthaFuknGreen
    Lodi, CA
    take them to a machine shop.
  7. boostin4fun
    boostin4fun Boosted ls/vtec ohh yeah!
    Omaha
    That is your best bet. A machine shop should be able to press the new pistons on for a reasonable price. That way you dont have to worry about damaging anything.
