HELP removing head/adjuster???
Discussion in 'Engine Building' started by EGxZEX, Feb 1, 2010.
  1. EGxZEX
    EGxZEX New Member
    California
    I am removing my head to get to the head gasket. I have already removed the camshaft sprockets. Do I have to loosen the valve adjusters? please help...:confused:
  2. Matts96HB
    Matts96HB . Moderator VIP
    you need to do the following to get to the headgasket:
    remove valve cover
    remove cam gears and timing belt
    remove cam caps
    remove distributor
    remove camshafts
    remove wiring/crap that connects to the head (exhaust manifold, accessories,etc)
    remove head bolts (deeper down inside the head)
    itll be loose at this point, just a matter of getting the leverage to pry it free
