One quick question! trans does alot of noise in high rpm going from 2nd to 3rd! only when im shifting to 3rd! could be the trans brakes!? thanks, im not sure!
Sounds like your synchronizer between 2nd and 3rd is starting to wear out. That is most likely the problem. Bring it to a shop while its still running and ask them what they think. DONT be shifting fast between 2nd and 3rd until you get it fixed. It will only get worse.
