HELP! Where does this connect to?
Discussion in 'ECU's, Electronics, and Tuning' started by gunsnbam, Sep 21, 2009.
  1. gunsnbam
    gunsnbam New Member
    I am so close to starting up my first car for the first time, but I can not find the connection for this anywhere. It it coming from the bottom of my ECU, there is another going up into the dash but this one is loose. I dont know how it came unplugged or what it is. Please help!
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    if its obd1 or 2 then it looks to be the port to retrieve trouble codes
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    just fire it up and see how it goes
  4. gunsnbam
    gunsnbam New Member
    1 More question. Its a 1995 Civic ex with a 1996 b18b engine. Can I use the ls ac unit with the ls ac bracket? Or is getting a del sol vtec ac bracket and using the stock ac unit the only option?
  5. TurboMirage
    that is no obd2 connector.
  6. D16SiHatch
    D16SiHatch New Member
    looks like a rywire jumper harness connector
  7. caboose
    caboose USDM to the bone
    Hamilton, MI
    +1
  8. necessaryevil
    necessaryevil New Member
    in da 503
    if you dont have and ece mods(hondata. etc) then i would say its the dash harness connector
  9. gunsnbam
    gunsnbam New Member
    Where would it plugg up to...the engine runs and I have driven it a little bit, but now that I am having a to time the engine I can not get the timing light to come on...nor will the CEL light up when I turn the key. (it should come on for 2 secs and then go off)...would this be part of the problem? no i do not have hondata or anything like that.
  10. necessaryevil
    in da 503
    pull back the carpet and everything else around there and just look around but it should be right around the heater box,
