Help!!! Will this fit???
Discussion in 'Engine Building' started by Moonwalker504, Jun 20, 2008.
  1. Moonwalker504
    Moonwalker504 New Member
    Someone is selling me a b18c1 edelbrock victor X intake manifold. Will this fit on my b18b?:confused:
  2. 89civicsnatch
    89civicsnatch New Member
    Cheyenne, WY
    Dont most or all B series interchange?
  3. efhondakid
    Akron-Canton, Ohio
    :no2:The vtec heads are slightly different than the non-vtec.
  4. Moonwalker504
    No it will not fit the b18 or No not all b series parts are interchangeable?
  5. 89civicsnatch
    Cheyenne, WY
    ok well thats good to know too
  6. Justin66
    Justin66 The Hondaswap Canadian
    Peterborough, Ontario
    B VTEC into B VTEC is almost always a perfect fit, depending on the car and sometimes the year. B VTEC into non-B VTEC wont always match like valve train. Im not sure about the manifolds.
  7. kevins39564
    kevins39564 Eric Cartman 4 President!
    Mississippi Gulf Coast
    Thats tricky cause the GSR b18c1 is a dual stage intake, but every other intake, B18c5 's head is the same as the b16 series, If i'm not mistaken the ls b18a/b are the same as the b16 series also.. Hmm.. i think the Flange has a minor difference and the dual stage deal.. Just ask if its a dual stage intake for Vtec (Standard on GSR Models ONLY) If it is.. theres probally another forum on here that will help you get it to work. Check for that before you get buy it.
    - Kevin
  8. fastest ls vtech
    fastest ls vtech New Member
    no wont fit ls to vtec only
  9. kevins39564
    your right your right, All vtec intake manifolds in the b-series are interchangable, Except the GSR mode (b18c1)
  10. kevins39564
    you can goto www.hondoctors.com scroll right down the page at that build they're doin they're running a victor X on a type R head (b18c5) its a badass intake man I'd rock it.. Definatly check on that alittle more info from the guy (Single stage or dual stage.??) More than likeley being after market edlebrock it may be a single stage wich would be doable on a b18c1 if you take the code out of the ECU that looks for it.
