Help with 1995 dual carb to fueliminate injected
Eg3 civic carby
I have a 1.3 dual carb Honda civic dx and I want to make it fuel injected as I have a b20vtec frankenstin motor ready to go into it..
I never done a build like this before and I'm pretty dam confused about basically all the wiring
You will need a MPFI engine harness. Typically, one for your chassis (1992-1995 Civic with D16Z6 is BEST). I'm not sure if the cabin harness is the same but I'm thinking it is. Then, a chipped OBD1 ECU (with knock sensor deleted) that is socketed for someone to plug into (laptop) and tune for your B20 Frankenstein. Or, a safe tune (for all OEM internals and stock head) would be a B18C Type R basemap. You need mounts, axles, shift linkage and O2 sensor (get all 1994-2001 Integra parts for these)
