Help with a d16z6
Discussion in 'Engine Building' started by Jdmjunior, May 22, 2015.
  1. Jdmjunior
    Jdmjunior New Member
    Need help with my d16z6 . What is a good setup ?
  2. E_SolSi
    there are a lot of good setups
    it kinda depends what you want out of it and what you want to do with it
    also depends on what your budget is
    give us some more information and we will be able to help you out a lot more effectively
  3. Jdmjunior
    D16z6 full swap.: hbeam rods low comp foreged pistons for high boost . 440cc injecters. Stock cam or stage 2 cam for low power. Titanium valve springs . Forged low compression turbo pistons . Cat back exchaust 2.5 to 3 inch for turbo. Tell me what u think?
  4. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    What's the stock injectors' cc? I'm just worried those injectors will max out with a turbo and built bottom end for higher boost. Guys run 1000cc injectors on stock K motors and 16-22lbs of boost. 750cc injectors max out on those set ups pretty easy.
    Don't forget engine management (ECU)
  5. Briansol
    440s will take you to about 275 whp.
    i still don't know what the question is...
