Help with axles!
Yeah, this is probably gonna seem like a dumb question but I am in the process of a swap and repair on a 93 del sol, swapping from d15 to d16z6 using 95 civic ex tranny but the axles are shot. will 98 dx axles interchange?
if they are both D engines then I think the axles should be fine, but do some more research before you buy anything because that is just a guess on my part
The only ones that wouldn't work are the HF axle, other than those, if it is D series it is the same as the others.
I'm guessing by asking about the 98 dx axles that means you allready have them or have a good deal on them?
otherwise I have a perfectly good set of D axles listed in the classifieds on this site
