help with boost controller and wastegate
integraspoon
please help. my boost gauge stays in vacuum. i got my boost gauge line in the intake manifold, i want to know if is ok to be there or is better to put it in the fuel pressure regulator, and if somebody can give some tips how to check my wategate because i thing stays open and thats why i'm not building boost?
my boost gauge line is connected to the intake manifold with the blow off valve too. i want to know if is ok to be there. i got an 95 integra.
:confused:under hi rev if u r under vacuum at your intake it beacause your turbo is not pushing air in your engine ... you should look closely to your turbo,intercooler,intake manifold connection make sure your gauge is well connected.about your wastegate i dont think it could cause u to have vacum ...but ill have to get more info on it.
