HELP WITH BRAKE PADS ASAP PLEASE
Discussion in 'General Tech and Maintenance' started by 95preludetypes, Jan 22, 2005.
  1. 95preludetypes
    95preludetypes Member
    im replacing my front brake pads on the 95 lude. i cant get the caliper back on the rotor the pads are to thick. how can i spread the pads apart. thank you for yor help
  2. 92civicb18b1
    92civicb18b1 The Trisexual
    you need to use a c-clamp to push the caliper piston in. I know on the rears you have to rotate the piston clockwise, I don't think u have to on the front.
  3. CRX-YEM
    Wallingford, CT
    you need to compress the caliper piston back into it's housing, use an old brake pad against the piston and a large C-clamp to push the piston back in. and everything should fit just fine.
  4. 95preludetypes
    thanks guys i got them on fine.
