Help with h22a1 turbo build
Discussion in 'Forced Induction' started by spoonhuntr, Jan 12, 2010.
  1. spoonhuntr
    spoonhuntr New Member
    Reading, PA
    Hey im new to the site, but not to hondas. Love the info here was wondering if you could point me in the right direction? I own a 96 integra with an ls/vtec and recently got my hands on a h22. Im looking to turbo it mostly daily driven. My goal is to break 300hp, with or without internals. Im new to the h22 and have been told stock can handle 8-10 psi daily. My question is what setup im gonna need for this goal? I have no reservations on sleeving, but mind you i live in Reading, Pa and theres no local shops to have my block sleeved.
  2. 99sidude
    Ohio
    Are you set on turboing the h22? I'd feel more comfortable shooting for the 300whp with the ls/vtec rather than the h22 if dealing with a stock block. Reason being, the fmr sleeves in the h22 are rather weak, whereas the b series block is fine at 300whp. Parts are also cheaper for the b series as well.
  3. spoonhuntr
    Reading, PA
    well to be honest ive always had a thing for the h22, and its something ive wanted to build for a good while. ls/vtec is cool and all but if im gonna drop some dough id rather do it on the h22. my goal is to break 300hp preferably with a turbo. as i stated i realized this will require sleeving the block i just wanna know what turbo/adds im gonna need to achieve this goal. this isnt gonna be a race car, just a fast daily driver and a personal satisfaction build.
  4. Matts96HB
    Matts96HB . Moderator VIP
    breaking 300whp on an h22 with a stout bottom end shouldnt be difficult. considering the engine is already close to 200crank hp, you dont really have that far to go
    you could easily get there with a pieced together kit, id recommend something like this:
    tubular turbo mani (ebay if you cant afford something nice
    garrett 60 trim t3/t4 (quick spooling on your h and decent power all the way till shift pts)
    2.5" downpipe and 2.5" exhaust
    bov of your choice (i recommend synapse synchronic)
    TiAL sport or synapse wastegate if you can afford it
    ebay intercooler and piping
    fastturbo oil line setup (or you can go to a local shop and have something made
    tap the stock pan
    not sure on the size of the injector youre going to need, probably some 750's to give you some room to grow
    walbro 255 fuel pump
    chipped ecu
    everything else stock and have that bitch tuned. should get you there
  5. DESPAIN
    flower mound TX
    awhat he said^^^^^^^ also i have an h22a that is about 400+ whp. i have a stock top end and am not sleeved. you can get mahle h22 forged low comp. pistons. you can run these without sleeving. see the h22 block is aluminum.so you cant run forged pistons. but with the mahle h22 pistons you can they have a coating on them. 300whp will not be hard to reach if you do it right.
  6. spoonhuntr
    Reading, PA
    I think I'm gonna go safe and have it sleeved to start (I've know how it is intending on basic build and ends up being crazy). Anyone know a good machine shop on the east coast? I'd like to keep the cost below $1k assuming I'm providing the parts.
  7. spoonhuntr
    Reading, PA
    Also has anyone had experience with hasport mounts? I've heard for the h series that hasport is the way to go due to the fact that they've altered the location for firewall clearance and tilted the motor to help lift the bottom another inch. Any truth to this?
  8. brenaan
    brenaan New Member
    Hasport mounts are the way to go!! they are really good. And also depends on what your swapping the h series in. Like my h swapped civic they are great and in my buddies h swapped integra.
