Help with Kill Switches
ElbowPunk
Trying to put a kill switch to the starter... which wire and from where should i connect my siwtch to it.... i got the fuel pump done
what else should i have a switch for ???? any ideas... 90 gs integra is the car i ride in... thanks
one way to do it would be to pull apart the column and find the wire that turns hot after you turn the key into the start position. follow that wire down until your more under the dask and then splice into it and put your switch outta sight. they will be able to turn the key forward and the lights will come on but after they turn the key forward it will act like it has a dead battery
