for timing the head, which timing marks do i go off, the same ones with the double marks level with the head or the single one for the mark in the timing belt cover???
Mini me is supposed to be a non-vtec block with vtec head.
I think you are confused. The crank pulley has lines on it red and white. Lign the middle one on the crank pulley to the timing belt cover and cylinder 1 is at tdc. The cam gear should have an arrow sort of thing on it and it is supposed to point up.
