Help With Motor Purchase
Discussion in 'HYBRID -> EG-EK / DC' started by project94, Jun 12, 2008.
  1. project94
    project94 New Member
    What would be the best possible swap for me and my daily driven civic other than the K series cause I dont have that much to spend on a swap... Also if anyone knows of a good place to order a motor swap from
  2. |Chaz|
    |Chaz| Well-Known Member VIP
    How much you looking to spend? www.hmotorsonline.com is a good site with a very good reputation.
  3. Dark93DX
    Dark93DX New Member
    B.C.
    Its really hard to say without more info, first off whats your budget like? what year and model is your car?
    K-series are out of alot ppl's budget, including mine;)
  4. project94
    I really dont have a budget but I dont wanna spead over about 4 grand and its a 92-95eg coupe... any suggests would be a great help and websites would as be great
  5. |Chaz|
    Are you doing the work yourself or taking it to a shop? What motor does your coupe have in it right now?
  6. project94
    It had a mini-me in it d15b block and a d16z6 head but i fucked the block up so i just want to get a new better motor and im going to do the swap myself maybe with the help from a bud i know... i couldnt really decide to go with the h or b series but im hearing the b series is way better...
  7. Dark93DX
    Dark93DX New Member
    B.C.
    B-series would be easier for sure, for a daily driver id say go with a 1.8L either B18B or B18C depending on what you wanna spend.
    ...but it wouldn't be nearly as fast an H22 or H2B swap:)
  8. BrutalB83
    Rochester Hills, MI
    That's not really a fair comparison. There's advantages and weaknesses to both. The H22 has more power and torque then any B-series swap, but the installation is harder and it requires fabrication...
  9. SLOWdelawareEG
    SLOWdelawareEG my cars go fast
    hilton head island, sc
    $4k will get you a CLEAN ass b18c swap. its reliable as a dd, and its pretty easy to put in an eg. like brutal said, the h series swap is not for a novice
  10. project94
    ok thanks for the help all.. b series it is
  11. eg6sir
  12. SLOWdelawareEG
    1 person likes this.
  13. |Chaz|
    :werd:
  14. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
  15. project94
    so what is required to do a b series swap in a 92-95eg and what is required to do a h22 92-95eg?
  16. BrutalB83
    Rochester Hills, MI
    Check out the FAQ/Reference section up at the top of the forums. We have articles on both I believe.
    In short though, the B-series is a bolt-in swap as long as you get the proper mounts and shift linkage. The H22 requires after-market mounts, plus some cutting of the transmission tunnel in order to get the shifter up through the floor. An alternative is to buy an adaptor plate and use a B-series transmission, but that adds to the cost of the swap. The H22 will also take up more room in the engine bay and add a little more weight to the front end then a B-series swap will.
    If you're looking for ease of installation, B-series is the way to go...
  17. project94
    Its not more that im looking for a easy install but more that im lookin for something powerful and that can take a good beating cause i drive harder than norm drivers on the daily... would a h22 spank the hell outta a b18 gsr in my car? and is a h22 as reliable and can take a good beating?
  18. project94
    btw great help all.. how do i leave rep?
  19. Dark93DX
    Dark93DX New Member
    B.C.
    hondas engines are all pretty reliable, but any engine will suffer damaged over time if you constantly beat the hell out of it.
    I believe ahhvtec has an H22 swap and I think I remember him saying he could take a GSR hatch buy 4 carlengths or something. some guys don't like the gearing of the H22 tranny nor cutting the car so there is also the H2B option as well (H22 w/ a b-series tranny), but the kits cost about $1300.
  20. BrutalB83
    Rochester Hills, MI
    Stock for stock, an H22 will take any B-series when placed in the same chassis. If you have plans to build though, you might want to consider the B-series since it's an easier swap and there are shit tons of parts available for it...
