Help With PA Sensor!!
Discussion in 'ECU's, Electronics, and Tuning' started by 2ToneRex, Nov 21, 2008.
  1. 2ToneRex
    2ToneRex New Member
    What's up guys,
    i have a 91 crx hf that i did a si (zc long block) swap a few years ago. everything went fine until recently when my car started "bogging" down while driving and eventually cut off. i would turn the ignition all the way off (while still coasting down the road) for about 10 sec. and then crank the car and it would run fine for a few min. i have had other minor problems as well but no big deal. ultimately i decided to do a ls swap hoping to resolve the issue. we got the motor in and it cranks and runs fine until it warms up and it starts doing the same thing, bogging down and cutting off. we have narrowed it down to the atmospheric pressure sensor (pa sensor) which is the code 13 on the ecu. we have taken 3 other pa sensors from scrap cars and the same thing still happens. my question is if there is anything that could cause the ecu to throw this code indirectly causing the pa sensor not to work correctly.
    please help and all comments are greatly appreciated. thanks
  2. E1337Fire
    E1337Fire New Member
    Hey, I'm having the same problem with mine and was wondering if you had found out any information about it yet? --Thanks Seth
  3. t3t4delsol
    t3t4delsol New Member
    York, Pa
    check the voltage running to it. if you still having the same issue with a new motor my votes the problems in the wiring
