ok im sure this is really easy but i just cant figure it out,
i have to replace my outside door handle on my civic but i cant figure out how to get the window crank off theres no screw and i dont want to pull on it to hard and have to get a new one of those any help
just pry with a screw driver. im pretty sure there is adhesive on there...just dont pry against the handle (cause it will break)...pry against the plastic ring (which might also crack, but its better than breaking the handle).
There's a little metal clip that you have to slide off. Pull the cap that goes around the window crank back a little and you should be able to see it. It is a bitch to get out. I struggled for about 10 minutes with a screw driver to get it out.
yeah lil metal circlip in there; pop it off by wedging a flathead screwdriver in there and then the crank comes right off with no stress. ps don't lose the circlip.
lol but i have my trusty flathead witch is a multi tool it was my starter for my 70 cutless it unlockd my girls friend car door and now a "window crank remover" lol
