i just put a obd2 b18b in my 95 civic coupe having problem with it not wanting to start i got spark and fuel and the only cel i have is 7, 10, 41 i have put new o2 in and new tps and the iac. still will not start up if i use starter fluid it will start but then die i am usin a obd1 dizzy and obd2 inj i have no clue where to start any sugg will be helpfull thanks
if it starts with starter fluid then dies you are not getting fuel... can you hear the pump priming when you turn the car on?
shouldnt be a problem unless there is a problem with the plugs/wiring do you have OBD-1 injectors you can try?
fug it out it was the fuel pressure regulator dont know what was wrong with it but put on a aem and the problem was fixed thanks for all the help though
