help with tps setting
Discussion in 'Engine Building' started by shaneb, Dec 4, 2003.
  1. shaneb
    shaneb Member
    Dose any one know how to set up the tps with the volt metter.............
  2. 92civicb18b1
    92civicb18b1 The Trisexual
    ground the black wire from the voltmeter to the chassis, use + probe to probe the wires and read what it says. I'm not sure which wire it is..jus check em all
  3. shaneb
    shaneb Member
    what should the volt meter say??
  4. 92civicb18b1
    .5 closed throttle, 4.5 WOT
