Help with tranny code?
Discussion in 'HYBRID -> EG-EK / DC' started by Darivative, Nov 10, 2002.
  1. Darivative
    Darivative Guest
    Does anyone know the exact transmission code for a jdm b16 trans. that has lsd? Any help would be appreciated!
    Thanks
  2. chet
    chet Senior Member
    st petersburg, florida
    Y1's came with LSD...but i believe S1's and J1's did also.
    to make sure, check the differential by looking inside the transmission, that is the best way to tell.
  3. chet
    chet Senior Member
    i was assuming it was a first gen b16 in my previous post.
    LSD was equipped in different transmissions after that...as it was an option in the 2nd gen b16a and b18c.
    most of the time LSD is stamped on the transmission on hydro types. for example, the transmission could be stamped with "S4C" and not have LSD, this could come from a new usdm civic si. if "LSD" is stamped then the transmission has likely come from a jdm civic type r. the same can be said for S80's. (integra transmissions)
    some have LSD stamped, like my jdm itr transmission, and other transmissions that don't have LSD are not stamped. to the best of my knowledge honda was very consistent with the LSD stamp on all of their hydro transmissions.
    but again, to be certain look inside the differential.
    also, read this article on transmissions...this should help...
    http://www.hondaswap.com/articles/viewer.php?id=45
