Help with tune on a 98 hatch with a b18c1 with type r internals
Discussion in 'HYBRID -> EG-EK / DC' started by realeztace, Mar 5, 2009.
  1. realeztace
    realeztace New Member
    My girls engine is at the machine shop right now getting work on it. We had the engine built at Trick Engineering in New England. They built a
    b18c1 with type r bottom end
    .02 overbore type r pistons (not to sure on bore size)
    gsr crower stage 1 cams
    stock valves
    skunk2 valve springs and valve retainers
    skunk 2 intake mani
    dc sports header
    an obd2 gsr ecu with a vafc
    The motor has been damaged. We pulled the motor our selves and brought it to a machine shop and we got the call that the block is like completely destroyed with worn valve guides and the deck was damaged by whoever last took the motor apart the last bore was made to big for the pistons and the pistons are worn. We are going to get this fixed. Keep in mind this is an NA build with the potential for a SC down the road. This shop is a good shop that will get the work done the right way this time.
    2 questions that I would like individual responses for please
    1 When doing the rebuild is there any other combination sugested such as different cams or pistons?
    2 What ECU and Piggy back with be the best combo for the build that we have stated above? I am questioning a gsr ecu being a good idea with type 4 bottom end. We are looking at hondata or a greddy e-manage. With either of these should we look at maybe a type 4 ecu? also keep in mind we live in an emissions state and need to hold on to a obd1 ecu.
    Thank you in advance and please let me know if there is any more information needed that I may have not included.
