i have in stalled a vafc and eveything is ok some times and sometimes my check ing. light comes on and the ecu is throughing code 21 witch is v-tec Solenoid, i have check the wiring a few times but can't find any thing.....
that's without a doubt a wiring issue with somethine you've installed. There is most likely a half assed wire connection.. did you solder everything? did you use crimp on connectors??
