htrcivic96sir
ok creating a budget and parts list for future swap... just wanna make sure these plans are in order. if there is anything Im missing and if there are any quirks to the swap I should know about, someone please let me know. appreciate the help!
Budget is very small... some where in the $2,000 range ( just swap.. no aftermarket goodies) .D16z6: scooped long block w/ 70k miles on it for $ 900 so that means budget is down to $1100
Questions:
do I keep stock harness/ECU, and wire for vtec? or do i go P28 and ex/Si harness?
I was recomended the EX/Si tranny for gear ratios' sake but am under the impression my D15 tranny will work fine ... should i go EX/Si or keep D15?
Do i need a different size banjo fitting for the fuel line where it connects at the fuel rail?
should I scoop a bigger intake pipe or just go get a cheapy APC/Ractive one? ( for the time being)
I plan on doing this swap myself Thanx for any feedback.
Questions:
